latunguley
Thread starter- Joined
- Jun 5, 2011
- 12
I just found a 1968 fiberglass speed boat locally that has what used to be a running 3.0 Mercrusier 3.0 inline 4 cylinder. So yes a donor boat for the motor since my 1999 Mercrusier 3.0 motor is seized and will not even come close to turning over. All of my 99 motor accessories are solid and still have a like new shiny black powder coated appearance. Fully functional. Electronic igniton is fine. Now theres some major differences between the two motors. One the inspection cover on my 99 is stamped steel and the 1968 3.0 is aluminum and shouldn't matter that it is? The 1968 has a points distributor and my 99 has an elelctronic distributor. I'm assuming that i will be able to swap the newer equiptment over to the 1968 Long block? But not certain that everything will jive properly? Has anyone used a 30 year span on 3.0 mercrusier to install in a couple years old mercruiser powered boat?? Please help. Thanks to all in advance for taking time to read and or reply to my issue. Thanks
