1968 mercury 500 #4 cylinder not firing
luckys pinstriping
I have a 1968 mercury 500 and have noticed that #4 cycles run not firing. All cyclinders have good compression at 130-135 pounds, all plugs are also working with good spark. Any ideas what would chase this. Plug is clean as the day I put it in and seems a bit wet when I pull them. I would assume it is getting fuel not sure why it doesn’t fire
Honorary Supreme Mariner
Look into crankcase compression issues.-------Reed valves.-----Lower crankshaft seal.
luckys pinstriping
Thank you, Racerone. Lower crank seal looks fairly easy to replace. How to i check the reeds?
Any thoughts on a bad exhaust manifold gasket or corroded exhaust baffle plate?
Thank you, Nick
