1968 or 69 55 Selectric
DeepCMark58A
So I picked up a 55hp Johnson Selectric. I don't really know anything about the motor any experts that can tell me some areas of concern with this motor?
jimmbo
Exhaust plate warping/corrosion causing exhaust to enter cooling system, Hydro-electric shift components can be expensive. Thermo-electric choke often quits working. Ignition components also can get expensive
In its day it was a very good engine. It had better thrust and top end than the 65hp V4 and burned about the same amount of gas per hour as the then current 33hp.
DeepCMark58A
Sprayed some fogging solution in the plug holes waiting for the key to arrive friday so I can see if it will fire.
