1968 Starcraft Holiday 18' - V - O.B.- 1st time project - 97% finished-Starcraft sec
Rich11304
Last November, I saw an ad on craigslist Free boat - 16' Starcraft - I contacted the guy and he told me that he needed it out of his yard that day for a Thanksgiving party. I went there that night and picked it up. It had plants growing in the back by the transom. The trailer held up just enough for us to take it home. It turned out that it was an 18' 1968 Starcraft Holiday V - O.B. on the serial plate. I needed the boat ready to go on vacation in mid-July 2011 to go to lake St-John, QC for a week, where I go every year and I like to bring a boat. The lake is 25 miles x 20 miles with huge waves during storms and this year we used the boat during one of the worst storm I've ever seen to rescue a friend and his wife on a sail boat. The boat and I got to surf 10 foot waves. It passed the test that day.
I started a thread last year but I'm not that good with post & threads and I was too tired from working on the boat. Drawing my inspiration from all of you, I started my project. The boat had been in salt water which complicated things. The hull had numerous leaking rivets and also pinholes from corrosion. I had to remove about 4 cross members with about 44 rivets each, I removed the knee that supports the transom tray and finally I had to remove the keel with about 100 rivets. I replaced all the rivets with stainless steel 10-24 phillips truss head machine screws, secured in the back with a flange nut serrated that I purchased online from Bolt Depot. For the transom In used 1/4 screws. The hole were patched with marinetek and an aluminum patch over most of them. I than applied "Gluvit". It took me months to make it water tight. I almost gave up when the boat fell to the ground during a leak test whenone of the stand broke under the weight of the water. The transom looked like swiss cheese. I patched the holes with marine tek. I cut a new 25" transom from 3/4 ac plywood $55 a sheet, I needed 2 sheets, glued 2 3/4 together for 1 1/2, epoxied it with 4 coats. I had a new aluminum exterior transom made and I had it wrapped over the transom all the way down to the tray that hold the transon, all held with 1/4 phillips truss head ss with flange nuts serrated. The Motor was a 115 johnson cross-flow that I just gave to "my marine mechanic" for spare parts. I replaced it with a 1998 Suzuki 140 EFI with 125 compression on all cylinders. I paid $750. The lower unit had a crack and had lost 1/3 of its skeg. The motor was making noise in the upper crank and we feared having to replace the upper bearings but once we took off the flywheel which was an experience by itself, we realized that the magnetos around the flywheel had unglued themselves and came apart, making the noise. Found a replacement on craigslist for $50. Anyway we had our official splashdown on July,19 2011. I know you guys don't really care for pictures & videos but I included a few.
IMPROVEMENTS:
1. 1998 Suzuki 140 EFI. 44 mph on gps without trim tabs
2. increased transom height to 25" with new aluminum skin wrapped all the way around to the tray.
3. New, larger custom-made corner caps
3. Deck made out of plascore/1708 fiber/epoxy + aluminum sheet backing.
4. Aluminum bow support with new wood/epoxied dashboard and other bow panel
5. Side panels made of plascore
6. Custom made 30 gallon below deck fuel tank that fits between the stringers - (Contact me via PM if you want to buy one)
7. par2jr, phase separation. Vent line dryer. Keeps the humidity level at 8% in my gas tank.
8. Painted it with an Interlux "VC Performance" with a Interlux primer "Interprotect 2000e
Attachment 111721Attachment 111722Attachment 111723Attachment 111724
Rich11304
Re: 1968 Starcraft Holiday 18' - V - O.B.- 1st time project - 97% finished-Starcraft
Can somebody tell me how to attach pictures that can be seen in the post as opposed to have attachment that people have to click on them? Thanks.
Rich11304
Here it is.
C:\Users\Richard\Desktop\1968 Starcraft 18 Holiday V - OB\#1 - photos\After
CheapboatKev
Hello!
First thing you need to do is sign up to a photo sharing site.
I like photobucket. You can set your settings to640x480 which I think are the max/best size to post.
Once you have your photobucket account and are ready to post..I open a 2nd tab so I have my iboats screen and my photobucket screen open at the same time
Make sure you are in the "advanced reply"
Click the icon for pictures
jump over to your photobucket page. copy the link like "(img) rich11304 holiday(img)"
paste the link on the pop up on iboats and hit enter
You'll get the hang of it
heyyou325
That's a nice lookin boat, especially for the price. And it only took 7 month's to get it ready. I'm jealous. As for pics, I use the same way you did. I joined photobucket, but haven't taken the time to join, or upload all, or any of my photos there yet. They just changed some things on photos, and you can send them that way bigger now. Works for me, why complicate things. Sounds like you did a good job on the boat, especially if it holds together in the waves you say. Good goin.
barato2
30 gallon tank? you planning on a run to the Bahamas or what? :cool:
Rich11304
Thanks for the info Cheapboatkev. I'm working on it. I selected all my pictures that I wanted transfered. There's a lot of them. I pressed the open button and it told me that I have to upload them one at a time. More work but I'm not giving up.
Rich11304
That would mean going in the salt water and she's a fresh water boat from now on.
30 gal is a good size tank for this boat. The lake where we boat is huge. It's custom made to fit perfectly between the stringers. It also lowers the center of gravity of the boat as well. Had the boat at 44 mph on gps without trim tabs (with about 5 gallons of gas) that will be installed soon. I'm also looking to build a long bench to for back of splashwell. Suggestions anyone?
Rich11304
The last 3 months were non-stop. I really needed a vacation.
heyyou325
A 30 gal tank, if you go out for a 3 day weekend where you can't fill up. I use just over 4 gallons an hour, that's just over 7 hours use. Course When I'm fishing, I don't use near that, but I'm also out for 4 or 5 days and 12 to 16 hr days. I have 2 30 gal tanks.
Brenn
Thats a great looking boat.Sounds like you did quite a job on it.Would love to see some more pics of it.
Rich11304
How do I go to "advanced reply"?
Hello!
Rich11304
25" transom wrapped in aluminum sheet,
bolted with 1/4 phillips trusshead ss bolts,
wood/epoxied/aluminum bow support
plascore/epoxy/1708/aluminum sheet floor,
Rich11304
Here we have pictures of:
Fabricated support for stringers and front floor panel, wood/aluminum bow support, gas tank
Rich11304
More pictures of rubber lined stringers to insolate gas tank,
Rich11304
Side panels made out of plascore/1708 fiber/epoxy/with wood door skin backing epoxied
Flotation: box built out of foam panels, epoxied placed within stringers, in front and back of tank,
filled with empty 2 liter bottles,
foam in with 2 part foam
Rich11304
Finishing installing the flotation, floor/gas tank and starting to paint the inside
Rich11304
Last coat of paint on the inside with picture of pvc pipes for electrical wires,
Installing rails and bow
Rich11304
My wife installing carpet
Mounting the 1998 140 hp suzuki engine
PARS2 jr to maintain low humidity in gas tank
Preparing windshield (This work is being done in Canada during vacation)
jasoutside
Did you guys see what he did with the flotation?????????:confused::eek:
There is more than one weirdo in the Starmada!:D
Great project Rich! :D
