So TrueWaiting is the hardest part, -Tom Petty![]()
Thank you, I did not know this existedDon't forget the camera!
Oh and for outdrive paint, they make Phantom black in rattle cans.
That's not nice.Well I have some bad news to report. About 30minutes in the oil pressure dropped suddenly to about 5 psi. I was able to idle back to port so that was good. I suspect I spent a rod bearing do to a light knocking sound on the way back. I'll update when I get a chance to pull the pan for some diagnostics.
ya know, your right, I hadnt thought of that. good IdeaThat's not nice.
Any chance a lifter got out of place. That will cause low pressure and some noise. I would pull the valve cover first and look at the valve train.
Hope the issue is not too serious. Make sure the crank journals are smooth before reassemble. A light polish may clean it up if necessary.Checked the main and rod bearings. There is some light scoring but I don't see anything bad enough to cause complete loss of pressure. Still have to pull the cam. I turned the oil pump with a drill and it's pumping so that's not it. I did see some extremely fine shavings in the oil pan, looked like glitter.
View attachment 341973View attachment 341975
Yikes. I've had some trouble with larger profile flat tapet camshafts that I use all roller stuff now.Well this ain't right..View attachment 342064
