Watermann
- Joined
- Jan 12, 2013
- 13,857
Not sure about wet sanding porous primer, never heard of that before?
Hull prep I strip paint, 220 sand hull, wash with cleaning vinegar, acetone if you suspect oil or grease. Painting I use the Chemical bond method with NO sanding. SE primer, hour later regular primer, after 1 hour base paint coat, within 2 hours top coat. All coats chemically bond as none are cured so in one long sticky day it's all done.
With the hardener, the VanSickle I use is the safest but just a time or 2 in your life spraying it. It most likely would be an issue if every work day of the week you're spraying it.
