1968 surftamer
surftamer guy
Hi I have a 68 surftamer open bow tri haul. I need to replace the strip at the front of the seam but there's no way anyone under 50 lbs is gonna reach it. Can anyone help me out? Do I have to split whole boat to get at it?17287843686465903765810108731855.jpg
Welcome
Only way I know of is to remove the rub rail
Remove rubber strip, drill out rivets then it will come loose.
There are other rivets under the rail that hold the 2 pieces together.
Will need a rivet gun (manual or air) to put back together
surftamer guy
Welcome
No rivets. Has screws that go the 2 layers and wood straps on the inside. Guess I may be able to drill new holes and try rivets
Could use stainless toggle bolts but they are costly
