1969 10'8" feathercraft with 25 yamaha?
junior1113
possible?? just picked this motor up and now i think its too big. i am a wood worker and a good transom might handle it. suggestions
tashasdaddy
Re: 1969 10'8" feathercraft with 25 yamaha?
like an uncontrollable rocket. i have one, it is stamped max 6 hp.
Chinewalker
There's a lot more involved in handling horsepower than a strong transom. Your Feathercraft is likely older than 1968, as I think they were done by the early 1960s. That means you've got 40+ years of the aluminum working, loosening, stretching, contracting, etc. I've seen a lot of Feathercrafts with cracked stringers - likely due to to hard of an alloy used back in the day...
junior1113
look up feather craft and you'll see that they were made in 68-69 just fyi.
jbjennings
I think you'd need to put a 300 lb man up front to try and keep that 25 from porpoising. I don't think the transom would hold it either, without pulling the transom corners apart. That is an awful light and short boat for a 25hp motor. I wonder why they were even together in the first place? Either way, sounds like you have a neat boat and a good motor! If you don't like them, I'd love to take 'em off your hands!:) Really, I don't think you'd ever get past 3/4 throttle without wrecking it. If you could get it to plane, a 10mph wind would be just deadly with that pair.:redface:
Later,
JBJ
kenmyfam
Way over powered in my opinion.
junior1113
had to buy the 91 25 hp yamaha for 300. but it turned out to be a long shaft so i traded it staight up for a 2007 merc. 8 hp 4 stroke short shaft. what a deal. are these little 4 strokes as tough as the 2 strokes?
kenmyfam
No idea but I prefer that set up !!!
