1969 25hp Evinrude overheated wouldn’t restart
BlackoutBill21
i Just posted about this outboard and what happened. But I just did a compression test and have a dead (58psi) top cylinder. 120 on the bottom
Question is where do I look first? Head gasket? Or did I fry the piston rings?? It was pumping water like a champ. I still don’t know why it overheated.
Vintin
Hopefully it is just the head gasket. Pulling the head is where you start and depending if you find ugliness inside or not, you decide where to go from there.
jimmbo
If you got it hot, the head may have warped too. Check it with a straight edge, length wise, cross wise, and diagonally. You might have to lap it using a very fine abrasive cloth/paper on a perfectly flat surface.
You may also want to pull the transfer passage cover to check the rings for tension, to see if the piston skirt is scuffed/scored. If the intake side of the skirt is scuffed/scored, the exhaust side is gonna be worse.
BlackoutBill21
Quick update... I got the head off!! Only broke 2 bolts!! I’m seriously excited cause it should have been all of them...soooo I’m assuming this motor is toast..
you guys tell me
Honorary Supreme Mariner
The powerhead is worth about 11 cents / lb scrap.-----Lots of good used parts available for that powerhead if you have the patience to look.
BlackoutBill21
But the block is toast no? Why buy parts for a bad power head? I have the patience... that how i got it running in the first place...
The block is SCRAP.-----Lots of those motors were made.-----I picked up a parts motor a while back at a meet.------$25 was all.----So lots to be found if you have the patience to look.----A new motor with warranty is another option for you.
BlackoutBill21
Yeah that’s what I meant... I found all the parts for this and 15 other motors I’m working on... finding a cheap block is not. But t as it sits i clearly have no other option but to look
54bobby
Grab another one for 300 or so and keep yours for parts
Chinewalker
That damage is more than an overheat. It took time to get that much separation from the block casting and sleeves...
BlackoutBill21
chinewalker... yeah thats what i thought..
funny story you guys might enjoy. I bought a seized up 25 hp for the lower unit to throw this powerhead on originally...........TOTALLY forgot i still have the seized up power head!! I already have a 25 hp block! lol didnt put 2 & 2 together... gunna take the block apart and see how the cylinder walls are.. I might have enough parts between the two to restore the seized power head!.
