1969 40 hp evinrude dies at 1/4 throttle
buckchaser1221
i have a 1969 40 hp evinrude that dies at 1/4 throttle runs fine at idle and revs up in neutral but in gear no power and dies out any ideas??
tx1961whaler
Re: 1969 40 hp evinrude dies at 1/4 throttle
Start by checking things out systematically and eliminating problems.
Check the compression.
Check the spark with a spark tester.
If both compression and spark are fine, then pull the fuel line at the carb and make sure the fuel pump is pumping fuel.
If all of that is good, then rebuild the carb.
buckchaser1221
ive gotten so many sugjestions to this problem wow i may as well go buy a new motor but this one ran great last year is it possible the coils and orpoints have any bearing on this issue thank you
tx1961whaler
They can, but don't guess. The spark test will catch if they are bad. The compression test, spark test, and fuel pump test will take a half an hour, tops
A new 40 will cost in the neighborhood of $4500.
A carb rebuild takes an hour and costs 20 bucks.
buckchaser1221
well did what you said went and got a carb rebuild kit rebuilt the carb took me 1.5 hrs everything spotless now it wont run at all unless i mess with the choke
tx1961whaler
Assuming you have good compression, good spark to both cylinders, and the fuel pump is operating, then all that is left is the carb. Did you blow out all of the passages with compressed air? Was the high speed jet (bottom of carb bowl) cleaned out with a soft wire?
Very good instructions here: http://forums.iboats.com/showthread.php?t=244013
You're very close to having it running. I have had at least 5 of these motors over the years, and I have a 1969 on the boat right now.
buckchaser1221
my carb bowl doesnt seem to have a hispeed jet that your talking about
tx1961whaler
It's number 60:
convert
coolguy147
an etec lol about 5-6 grand
buckchaser1221
theonly numbers i can find on this motor are on a tag by the thermostat they are 40753e and eo4195
buckchaser1221
it would appear the only thing there is number 62
buckchaser1221
i can get it running now ifikeep the throttle higher but it has a bad cough constantly that dont change with the top jet adjustment
tx1961whaler
OK. The cough is caused by it running too lean. The low speed needle valve should be able to adjust this out. The needle (#43) can be backed all of the way out after removing the packing nut (#50), and you can spray carb cleaner (or WD-40, in a pinch) through to try to clear the passages. You can also use compressed air, but ypu may have to remove the packing before trying that.
buckchaser1221
i thank you greatly for your advice and will let you know the outcome of my situation as i am done tinkering for the day thank you again its very appreciated
coolguy147
well is it like a sneeze?
or is that it dies then slowly comes back to rpm?
umm check spark. need to see if its at least sparking or if it has a missing one on and off. also probably should get a ncie rebuilt kit with a new float. this will alow u to make sure u dont have a leak in fuel or air anywhere.
have u replaced the impeller recently?
theres a nice threads at the top of the johnson evinrude forum. abotu carb adjusting.
so just start out put ur high speed needle at 1 out and low speed 1 1/2 out. to start off
buckchaser1221
fried lower unit last fall so i replaced it the only jet on the carb is the one at the top of the carb its like a sneeze
