1969 55 hp johnson no spark
lloydearl
I have a model trl-10r i have no spark. i did notice the fly wheel was magentized when key was in the on position. Is this normal I have not look under fly wheel yet? any info would greatly be appreciated.
F_R
Re: 1969 55 hp johnson no spark
Flywheel was magnetized when the key was on???? Well that is a new one, and I don't know how to respond. Let's just say it is not a normal test. There are permanent magnets inside the flywheel.
That is a complicated and expensive ignition system. Proceed with caution at your own risk, if doing it without a manual and some education. After all, it's only $$money.
lloydearl
I defiently don't want to get into anything to complicated. But I would like to test basic stuff with a meter. I got 16.8 volts from the power pack to the coil so I don't know if that is up to par or not. The next thing to check would be under the flywheel I guess.
scup27
are both cylinders not sparking or is it jsut one? make sure the grounds are not connected to the block, because that would cause there to be no spark.
bktheking
I posted a reply to the thread you tagged on to.
lloydearl
I got no spark on any of them. I am also not geting any amps from the ignition coil. When you crank it you should get some kind of amp draw I would think.
