when checking the spark on my 1969 55hp evinrude<br />I pulled each spark plug wire off one at a time with the muffs on and got the following results.<br />number one cylinder engine dies to the point of almost shutting off. Number two and three cylinders I could only tell a slight difference in the running of the motor. I checked the compression and it is 123 on each cylinder. I have new points set at .10 new plugs set at .30 recently rebuilt carbs and a new amplifier. My question is would this be normal or do I have an issue with plug wires. Thanks for any help
