17bellboy
Thread starter- Joined
- Mar 15, 2009
- 21
Re: 1969 85 hp evinrude hydro electric issues
hmmmm..... Not sure what would cause the issue only when the motor is running. I did the rectifier ohm check (it is also a new one) and it passed. Then I fired up the motor and the stator is giving a pretty consistent <13> vac. But when I check the red wire coming from the rectifier it is giving voltage all over from 2 to 12 volts, the same as the leads for the solenoids. But again, with the motor off and key on the shift leads have a good 11.5 volts.
