68glasspar
- Joined
- Aug 28, 2024
- 118
I see the wiring diagram shows a temp light on this engine application! I will test that
Far too many times we hear "I have worked on Auto Engines, or Aviation Engines". That kind of means Nothing when it comes Older Outboard Engines. An frequent Example, is how many "Experienced Mechanics" insist on trying to set Idle Timing... or adjusting Carb Linkages to adjust the Throttle Valves to set Idle Speed...I retired 1yr ago after working 35yrs as an auto mechanic and currently still an aircraft mechanic!
Found bad head gaskets, probably caused by by water pumpThe original pump housing was cast aluminum.---I do not believe they market kits for these.---Your local dealer can find the parts for you.
that's a lot of valve grinding compound!Heads are likely warped.----Need to be refinished.----A flat surface ( piece of glass ) and valve grinding compound does the trick.
I got my heads flat and have new head gaskets that say to use no sealer!Heads are likely warped.----Need to be refinished.----A flat surface ( piece of glass ) and valve grinding compound does the trick.
