1969 Chrysler 55hp air leak
bvsteamer
I have an ongoing problem with my outboard. It has Magnapower ignition. The electrical has all checked out ok, and all the fuel lines, primer bulb has been replaced, as well as the lines that "power" the fuel pump. The tank has been cleaned and the fuel pump and carb rebuilt. I still have a fuel "starvation" problem that causes a backfire/missing problem. The primer bulb gets very soft after running a while, and fuel barely dribbles into the fuel filter. Acts like an air leak.......any suggestions on where to look?
Frank Acampora
Re: 1969 Chrysler 55hp air leak
If you have a quick-connect fitting at the tankcheck for a clog there. If the bulb gets soft, it is probably not an air leak but also check the Oring inside the femal quick-connect. They commonly wear out and do leak air. As Zoppy said, check the tank for crap inside it and if it has an internal strainer check that for partial clogging.
