Noblo88
Thread starter- Joined
- Jul 2, 2014
- 39
So I just bought an old boat with a motor that doesn’t run, used to run last year, I thought maybe carb. It was clean as a whistle as if internals were brand new, didn’t clean much as I also couldn’t find a jet like I would on a old truck carb or lawn mower etc, noting to unscrew and pull out. I pulled apart the full pump and everything seeming fine, no clogged ports and I made sure it was all put back properly and I can see fuel going from the pump to the carb so that checks out. The carb has good vacuum suction as well when I try to start, the top screw on the carb was out 3 turns so I went in and back out to 2 1/2 and spark plugs all have good solid spark. It won’t fire or even sputter, I do get a real nice backfire after a bit. And when I put some gas into the carb it just gets to backfiring.
