Kawaiikeno
Thread starter- Joined
- Oct 1, 2019
- 68
Hi While trying to fix an issue with the motor just stalling at idle I've ran across something I need help with. I purchased a sierra tuneup kit 18-5002 after installation of just the top set and checking with a timing light the timing is aprox. 3/4" out of the two marks to the left of the marks. After comparing the old set with the new ones I found the distance from the center post to the rub block on the new sierra points is about .050" longer, I then purchased a set of OEM evinrude points #0580148 from the local dealer that are listed as the correct points they are seemingly the correct length but the plastic bushing in the points is too small to fit over the post.
What I've done to get it working is to replace the small bushing in the OEM points for the larger one from the sierra set. This has returned the timing between the lines spec at .020"point gap.
But has done nothing for the intermittent stalling so far for this issue I've replaced the coils, plug wires, points, condensers and had the carb apart several times.
I'm open to your thoughts and advice
Thanks Mike
Thanks Mike
