1969 Evinrude 85 HP
jfmil355
I Have a '69 Evinrude 85 HP that misses at low rpm. I replaced the spark plugs and it made no difference. Any ideas?
oldcatamount
Re: 1969 Evinrude 85 HP
I'd say you need to clean/re-build the carbs. Have you tried adjusting the low speed needle valve (if it has one)? That miss you're hearing is called a "lean sneeze" and maybe a tweek of the low speed valve will help.
emdsapmgr
Follow oldcat's suggestion. Likely the miss is fuel related-not spark. It's probably running lean.
