kfa4303
Banned
- Joined
- Sep 17, 2010
- 6,094
Re: 1969 Evinrude Fastwin 18HP troubles
Hello again 870. I've circled the two lines used as a timing reference in the pic below. The "stop" portion of the twist grip is one way you can kill the motor. It simply retards the timing to such a point that the motor stalls and dies, but you have ot be careful, or you'll keep killing the motor every time you throttle down. You can prevent to motor from dying when you turn the throttle all the way down by adjusting the idle set screw found where the rear tiller gear meets the vertical throttle tower which passes through the lower cowl pan. I don't like it when the motor dies simply by turning the throttle down, so I twist the screw in a few turns to prevent the motor from stalling. To kill my motor I have installed a push-button lanyard kill switch. It only costs about $10, installs in about 5 min., adds an extra layer of safety and works like a charm.
