1969 johnson 115 no spark
utfordgrl
we replaced the plugs and we have a new stator have any suggestions we're not getting any spark
rockyrude
Re: 1969 johnson 115 no spark
On my 69 115hp there were two wires that went from the power pack up to the trigger under the flywheel and were tied to the advance arm and had corroded and grounded to the advance arm rendering the trigger useless. They can be replaced with a little effort.
bigpoppakdog
1. bad wiring to terminals.
2. Bad powerpack.
3. Bad coil.
4. Stator has NO bearing on spark.
5. Clipper switch installed on this motor?
6. Neutral safety switch bad(doubt it though.)
7. Bad sensor wire like other person mentioned.
8. take flywheel off and inspect for damage on the plate-sensor-spark plug wires.
is the motor turning over? When you turn the switch to on, do you get volts going to pulse pack? I believe its terminal #7(purple wire). If you do, you should get a dva meter and then measure the output from the pulse pack when cranking motor. If you get no output then you know you have a wiring issue or a pulse pack issue or sensor issue. A sensor wire could be a problem too. I guess it would help if you provided a little more info on what you have done already.
