Hab
Thread starter- Joined
- Jul 4, 2017
- 158
Well I learned something today about the solenoids that may be the source of my problems, besides oil volume. So the solenoids have been removed 2X and probably not seated correctly either time. JoeReeves says the plunger should set below the solenoid by 1/64". I know when i slapped mine together the plunger was proud of the solenoid, but i had no way of knowing better. the cap has an indentation i assumed was to receive the proud plunger, but maybe not. Oh boy i cant wait to remove the lower unit again. Anyone ever filled the lower unit with oil through the solenoid cap, seems like it would be way easier to dump oil in that way than what I did before.
Joe's instructions, post 13, the motor hes discussing is a 72 and may be different than mine.
https://forums.iboats.com/forum/eng...de-outboards/10659984-hydroelectric-solenoids
What i think may be the problem. If i remember right i tested the plunger, when i reinstalled it, to be sure it would move freely up and down against the spring. I'm not sure there was a way to set it below the plunger. Anyone else had these out and set the plunger to a specific depth?
