sherlockian
Thread starter- Joined
- Jun 13, 2006
- 3
Hello, I am new to boating. I just purchased an old 12' fiberglass boat with a Johnson 9.5 hp on it. The engine was not running when I purchased it. The owner said he thought the fuel pump was bad. I bought a fuel pump and carb kit. I rebuilt both and reinstalled them. I also replaced the water pump impeller and spark plugs. My problem is that I took the boat out and the engine would run excellent(idle to full throttle) for about 15 mins. Then the engine would slow down by itself and eventually quit. It would take about 20-30 minutes before I could restart it. Again it would run fine for about 15 mins, then the cycle would start again. I only did this three times to cover some long distances and used my trolling motor the rest of the time. I need some advice because this is the first outboard I have ever dealt with. I am thinking that the "electronics" are going out, possibly points, condensers, or coils. If anyone could give me some advice or help, I would appreciate it.<br />Thanks
