ajax5240
Thread starter- Joined
- Aug 6, 2011
- 134
I just bought a fiberglass 16'er with a tower of power 1250 on it. I am an automotive tech but new to the boat world. The motor fires up good and sounds good. Today was the first run at the water. Came up with two issues
1. - the motor will not come up to full speed, at full throttle it sounds like its bogging a little and won't come up on plane. What should I check first? Compression, timing, carb adjustment?
2. - it sounds like reverse is not engaging correctly, sounds like it goes in gear ok, but when you give it some throttle it makes a grinding like it is coming out of gear. Reverse seems good out of the water with the muffs on.. is there linkage adjustment that I should make to get it to engage fully?
Thanks for any help!
