1969 merc 1250ss vs 1984 merc 115
TomSawyer
My question is which one has more power at the prop?
Will the 115 bolt in where the 125 was? (electrical, controls, trim etc.)
79Merc80
Re: 1969 merc 1250ss vs 1984 merc 115
The 84-88 115 had about 135 at the flywheel, so I doubt that you could notice a 10hp increase. From 84 on, Mercury went to the industry standard mounting bracket which is wider than what they used through 83. From 84 on the power trim/tilt w2as integrated into the mounting bracket instead of having the pump inside the boat and 4 hoses going to the rams. The control cables are universal, but the electrical plug is different. In 1980 the plug on the side of the cowling was removed and the connection was put inside the the cowling behind the face plate support with a different plug.
If I was you and had the 1250, I wouldn't change unless it's getting tired. Sometimes I wish I had the 1250 that I grew up using instead of the 90 (1984) if have now.
TomSawyer
Thanks for the info. The ol' 1250 is getting tired as the compression is from 105 to 85 and it runs rough. (surges and misses at wot) and now it wont go into reverse. I have a line on a 84 115 for $500 but it doesnt sound like it is plug and play. I think I will keep looking for a replacement. A 70's 1500 would be nice.
