- Joined
- Jul 18, 2011
- 18,137
Hi Gang,
I decided to start working on my old-ish 1969 Mercury 7.5 hp . . . It needs a whole new water pump along with a prop shaft bearing and new seals.
Right now I am 'trying' to get the retaining 'ring' nut off and am wondering it there are any tips/tricks to getting the 'nut' to break loose (goes clock-wise to loosen). I have the special tool for the retainer nut. My concern is getting a good enough grip on the LU housing so I can put a sufficient amount of torque to break the thing loose.
Last time I took the LU apart, a PO had already trashed the notches on the ring nut, so I ended up cutting the nut to remove it and replaced it with a new one. This time, I'd like to take it out intact.
I'm using my workmate bench as a clamp, but the LU is currently winning the fight.
Any tips/tricks from the Mercury outboard experts :noidea: . . .
I just don't want to damage/crack the housing by putting too much force and not enough support in the right places. I already tried some mild heat, but that did not seem to work. I could get a torch to put some more heat on the housing . .
Salt water use, if that makes any difference.
FWIW - I've already 'invested' $$$ in this LU by replacing the carbon steel drive shaft with a SS shaft from a 1980-ish motor, so I'd like to be able to fix the pump, bearing, and seals to keep it alive.
