rusty_shackelford
Thread starter- Joined
- Feb 25, 2017
- 3
I have a Mercury 650 Thunderbolt 4-cylinder. The serial number (2504342) tells me that it was made early in 1969.
The wiring in the motor has been jacked up by at least two different "mechanics" over the years. Instead of replacing the crumbling wiring harness, they just drilled holes in the side and ran their own wires (old trailer wiring) to various components. I've decided to replace all the crazy wiring with a new proper wiring harness.
The first issue is that the motor components don't match the schematic. THIS the wiring diagram (http://www.maxrules.com/oldmercs/Wiring/1966ona/30.gif) for my motor, but THIS ONE (http://www.maxrules.com/oldmercs/Wiring/1966ona/26A.jpg) actually matches the components inside the case almost identically.
So I went with the wiring diagram that matches the components. That brings me to the solenoid. There was an aftermarket (Hitachi 104-136) solenoid wire tied in place. The Hitachi has no markings on it. Just a yellow wire and a black wire and the much larger 12v terminals. The yellow wire was attached to the starter switch and the black wire was screwed to ground. I got a proper solenoid, but I'm not sure how to wire the terminals. The 12v+ terminals are easy enough to figure out, but does the yellow wire from the ignition switch go to the "S" terminal or the "I" terminal? And should the other terminal go to ground or just not be used, which appears to be the case in the 26A wiring diagram that seems to match my motor?
I hope I made this clear enough. I'll answer any questions ASAP. My big fear is that I'll cause a fire or worse... have to buy another $115 wiring harness!
Many thanks for any advice given!
