BudL1te
- Joined
- Jun 8, 2012
- 63
I have a 1969 Crestliner Tri-Hull with an OMC outdrive. The motor was Gray and roughly the same a the mercruiser 120 I put in it. (Chevy II engine I believe)
This is an electric Shift drive.
I have a plug on the bottom left, a plug midway (or a little more) on the right hand side, A plug (Large Flathead) at the top (no dip stick) and a large plug about midway at the back that feels plastic and is raised (Not flush like the other plugs.) I took the lower plug out and oil came out, I tool the plug from the right upper and oil came out.
I am confused now. I haven't see any similar to mine in the threads or you tube.
What is the best way to change this oil???
I tried to blow air in the lower plug and it did not appear to push anything through the right hand plug as I was expecting so I am stopped here.
Any Ideas?
Any Ideas?
