MinnStarcraft
- Joined
- Oct 16, 2010
- 52
Re: 196X Starcraft Holiday-1975 OMC Johnson V4 115 Restoration
Yeah, I was surfing craigslist for SC boats and just stumbled upon it. Guy even delivered it to within 3 blocks of my house. Can't beat that. Angle on the stringer seems to be the no hassle approach.
Thanks Jas. I will be looking for lots of input from you for sure (I hope).
Yeah Watermann, its actually a 32 gal Capacity tank. Not sure on the rubber. I do know that rubber compounds do affect aluminum but to what degree, I don't know.
Tank sticker...
Yup, I read that tank install info awhile ago and was thinking about doing that. I was trying to think if there was any synthetic rubber that could be used as per Watermann's suggestion to bed the tank. After staring at the problem, I think the best bet so far is to bed the tank on some epoxied marine ply strips on each rib. I can't think of an easier way so I will go that route. I will get some 1\4 inch Marine plastic for the strips to mount on the tank. Painting the tank, huh? I guess I should do that since it's already out and all. No sense in tryng to cut corners and I DON'T want to take the tank back out again if there is a leak if I can help it.
___________________________________________________
Ok, I am working on filling the corrosion holes on the transom skin with JB Weld. I am only hitting the big divits. While I am at it, was thinking about 1 big patch to cover these kicker motor mount holes. There are 8 of them.
I thought about welding but the issue of warping comes to mind. If I patch, I have one of these to go over it.
Not sure if it will work as it it pretty tall for that transom:
Wow $20! I paid more than that just for a couple pipe nipples to build mine. I'm planning on using neoprene isolators on the ribs under the tank. I would see about having some angle welded to the tank so it can be mounted to the stringers.
Smokin deal!
I'd prolly use flat stock alum across the top, and at both ends riveted into the stringers. I'd also wedge it in with some foam
Awesome score!
Wow that is one heck of a bottom feeder deal on that tank! Is it a 30 gallon?
I would go with some type of rubber to bed the tank on.
Tank sticker...
Best not to use rubber, it's reactive w/ aluminum, or foam (it can trap water against the tank)
I'd prep the tank, spray a light coat of SE/ZC primer, and paint it before you install it below deck. Then follow the recommended steps here for installing an aluminum tank.
The prep, primer & paint is to protect the aluminum from any water it does come in contact w/, and would be just 1 more way to minimize the chance for water &/or corrosion damage...
