steviecops
- Joined
- Oct 3, 2003
- 585
Hi<br />It will start up on full choke, with the throttle advanced past the start mark, after a lot of pulling, but it only runs for about 10-20 seconds before it just loses power and dies. If I try to open the choke, or move the throttle back to idle, it'll die immediately. When it runs at high revs, it surges a bit.<br /><br />I've had the carb apart and thoroughly cleaned it several times now, although I haven't installed a new carb kit. I have installed a new inlet needle and seat though. I've had the flywheel off and changed a bad coil and cleaned and re-set the points. I've now got a really hot spark on both plug leads. I've had the reed plate assembly off and cleaned everything up. The reeds are sitting nice and flat and are not sticking. Compression is just over a hundred psi in both.<br /><br />The only thing I can think of doing now is fitting a new carb kit and changing the plugs. But somehow, I don't think that it'll make much difference. Could this be a faulty upper crankshaft seal? There wasn't any sign of oil on the magneto plate when I took the flywheel off, although there was some under the plate.<br /><br />Also, could anyone tell me what year this engine is? I've checked the old OMC site, but the numbers don't add up. The numbers on the plate say 44B37R B 4562.<br /><br />Thanks<br />Steve
