sonicgarden
Thread starter- Joined
- Aug 14, 2007
- 4
hey all,
I have a 1150 inline 6 late 70's distributor model thats having issues.
It took forever to start, when it did get started, i let it warm up for about 5-10 minutes...we boated around the lake for a while at 70% throttle then she began to lurch until finally we lost all power, it choked and died.
I have a generic manual for the inline 6 and have started work on it but still have some questions that the manual doesnt answer...hopefully y'all can!
1) The primary timing is supposed to be set at 4-6 BTDC as is stamped on the sticker on the mount but how do you adjust it?! where is the screw or "tang"? I know how to set the max spark advance with the screw for 21 degrees BTDC, but how do you set the primary timing?
2) there is a little blue electical do-hickey that seems to have one wire coming from the distributor connected to it, which in turn is connected to the ignition/electical panel and then there is another wire coming outthe end that seems to be a ground wire because itas just screwed into motor frame. Any ideas on what that is? One of the wires is severally compromised and it seems you have to replace the whole unit, but i dont know what it is?!
3) on the boat i have, there is a little rubber hose that comes our of the spedometer mounted up front...where do I connect this hose on my motor so that my spedometer works?
4) I think i have identified the fuel pump, but what it the fuel filter? is it that white cylindrical container about 2-3 inches long? If i get a new one, do I replace that whole thing or something inside of it?
Here's hoping you all can help!
