saltysenior
- Joined
- Jul 10, 2007
- 31
back again......this time w/ a '70 4hp md#40063......how do you tell if she's pumping enough water, because it could be a pump problem or a blockage problem...
The engine will spit water out of the 8 relief ports but you won't see a steady stream. Also you want to run 24:1 in that engine. The book will tell you 50:1 but there is no needle bearings in it.
Your local dealer should have the impeller for that engine my dealer stocks it.
