1970 60073D 60hp evinrude
Handyman72
Gday all
After finding the ignition coil has 3 cracks around the insulation and bad wires,in Australia there are no coils available unless someone can point me in the right direction,
Cheers
Available from ----cdi-electronics----US $45.99--Or I have a number of used ones here.-----But you are too far away at this time.-----Have you removed the flywheel to clean the rotor / distributor cap / set the breaker points at 0.010" ?
Handyman72
Yes I removed the fly wheel and cleaned everything up,it was fairly clean ,no rust,points excellent condition, the cap had 2marks either side where it ignites but no damage,there was a retaining clip for the base missing,there was two not three,so the base did move a little bit before i put the third cip on.no cracks or burn on the stator all checked out above all excellent condition. The coil has three cracks around the insulation and the earth wire casing is brittle and exposed
Cheers
