1970 60HP Evenrude!
Daltonxj
My brother - n - law just got a 1970 60hp evenrude. we have been trying to get it to start. We have a good (new) battery. cables are in good shape. the previous owner installed a CDI 113-7123 battery power pack. not sure if or how to test this thing. I found a page on how to install it. and do some trouble shooting on it. But still no luck. I have read and searched the manual I have but still no luck. still reading the manual for more info.. if anyone has any sugestions to try let me know. really confused on this thing..
the engine turnes over but has no fire to the plug. (tested with sparkplug tester)
F_R
Re: 1970 60HP Evenrude!
You have to do some orderly, systematic troubleshooting. Fisrt make sure you have 12V (+/-) to the amplifier when cranking. If not, backtrack to find the problem.
Secondly, disconnect and remove the coil and unscrew the spark wire from the distributor cap. Then remount and connect the coil, and rig up a spark gap from the end of the spark wire. Crank engine. Do you have spark at the wire? If you do, everything is ok up to that point and you have a problem in the distributor cap.
If no spark, disconnect the black & white wire that runs between the amplifier and timer base. With key turned on, brush the amplifier-end wire terminal across a bare, grounded metal part. You should get a flurry of sparks across the spark wire gap. If you do, everything is ok up to that point, and trouble is in the distributor. If no spark, you have a bad coil or a bad amplifier. It is cheaper to try a new coil than to try a new amplifier.
OK, if you have determined that the trouble is in the distributor, it is time to remove the flywheel and distributor cap for a looksee. First thing is the breaker points. They should be immaculatly clean and gapped at exactly .009" at their widest opening. If the silver anti-reverse cutout ring is shot, replace it. If not shot, lubricate very sparingly with just a bit of EP grease. The tab on the anti-reverse terminal does NOT stick down through the loop in the spring!!!!
Lastly, inspect and clean the cap and rotor. Remove (unscrew) the spark plug wires and test them for continuity. Use a bit of grease in the caps when you reinstall them, per the manual.
By this time you should have located the problem.
EXTREMELY Important---When you reinstall the flywheel, make sure the tapers are clean and dry and use a torque wrench to tighten the nut to specs. 70-85 ft/lbs, if I remember correctly.
One other thing. If it still has the surface gap spark plugs, trash them and install Champion L77JC4 plugs gapped .035". Those motors never did run well on the surface gap plugs, and never will.
Daltonxj
will be checking on that tommorow. thank you will let you know how it goes...
Daltonxj
Well we check everything you sugested and found spark at the coil. so we removed the flywheel and cleaned and regapped the points. as we where cleaning the plug wires by unscrewing them the coil wire just fell off the brass screw piece.. so a little sergery and it farked up.... so we switched a plug around after cleaning to see if it would fire over ...
Nope no luck so we have narrowed it down to the distributor part with wires... now to find a new dis and plug set..
I looked on IBoats but can't seem to locate the right one.
can someone point me to the right parts I need??
