Had the boat out last night for first time this season and motor will go from idle to wot no problem then after 20 secs revs drop to about 3800 and I back the throttle off and everything is fine engine idles fine also. Then if I want to I can go to wot again and repeat the process.
When I got home I discovered a leak in fuel line on carb side of fuel pump. I found this by squeezing the bulb on fuel line and holding it tight. So I fixed that and came on here to read up on any other possibilities. I was going to pull the high speed jets tonight and clean them. Any other items I should look at?
