hardwater fisherman
Thread starter- Joined
- Mar 19, 2010
- 1,725
I bought a 1972 25hp last fall and the 6hp was a throw in..... I think the 6hp is probably the better of the 2....The motor had new coils points and condensers when I bought it..... I have put a carb kit and impeller as well as a new thermostat... I have got it to idle super slow in neutral and both gears running in a barrel..... It takes throttle and back down to idle nicely without flinching... The only problem is it needs to be on the the high part of the cam to start..... There is a mark on the cam and it will idle when the follower is on that mark... I am putting it on a boat Friday for the first time to see how it does... I think it is going to run well but it really revs while starting.... I can pull for ever until I throttle up and it catches right away.. It does not seem right to me but maybe it is normal?
