I have a water leak in my lower unit. The motor was getting hot so I changed the impeller, all lower unit seals, the t-stat, and springs. The manual says that the engine should shoot water out of the exhaust relief holes when the motor is at operating temp. The water is coming out around the lower unit where it attatches to the motor. I assume that it should have a gasket or sealant around that. I checked for sealant or gaskets when I disassembled the engine and there wasnt one. The motor is cooling, but the water is leaving around the lower unit instead of the exhaust holes.What should I do?
