1970 9.8 2 stroke no start
bvsteamer
I have an older 9.8 2 stoke that possible overheated. It ran about 1 minute with the telltale barely dripping, and then died. I replaced the impeller, but now it will not start. Compression is 95 on both cylinders, replaced the spark plugs as well. It is getting fuel....any other potential issues from possible overheat?
Re: 1970 9.8 2 stroke no start
Are the plugs getting spark.??? :confused: no spark means no fire to the cylinders which means no spark which means no runnoo!:D if there is no spark then it is and ignition problem:facepalm: ...which can be a big headache to locate the exact failing part.:rolleyes:
