1970 9.9 crysler motor
10weston
1970 crysler 9.9 outboard wont start i have 120 compression on both plugs good spark steeped carb new kit fuel pump new kit i dont know what to do to get it started thanks john
wickware
Re: 1970 9.9 crysler motor
Are the plugs showing signs of getting fuel (good smell or damp)? If not, spray 1-2 good puffs of your premixed fuel in the carb while trying to start.
Frank Acampora
Some are a little fussy starting the first time and the reduction gear starter exiting through the front won't spin the flywheel fast enough. Try wrapping a rope around the flywheel pulley and starting that way. Once you get her running, she may start easier in the future. I run my small engines onece a week to prevent this kind of starting problem.
Be sure you open the throttle to the start position and choke the engine for a cold start.
10weston
thanks for your info ihave tried all is the pudle valve have any thing to do the screens were missing
i checked the reed valves the are flat on plate gas is not going from carb to plugs
what should i try next thanks john
jim j geezer
Probably time to *CLEAN* the carb. But before doing that, remove the fuel line that feeds the carb and then crank the engine. You should see fuel pulse out in spurts. If not, then backtrack fuel source - including quick-connects.
wickware
Do you have fire with the plugs installed while under compression? I had engine analyzers at one time and could see this fire and know it?s possible to fire outside but not inside. I just got a 5.00 spark tester just for this experiment vs needing it. I am interested in seeing if the 5.00 instrument works and how long. Plus, it could become handy.
Most of all! If you have fire, prime it, it should fire even if it does not continue to run. This would help eliminate some possibilities in your challenge.
10weston
thanks for the come back im going to try to remove hose from fuel pump to carb pull starter to see if any gas
comes out thanks john
