Celtichawk
Thread starter- Joined
- May 6, 2012
- 564
Okay guys boat running great, however, I had the outboard motor in up position while sitting in my driveway for 3 days and I came out today to a oil leak of some sort. I will post pictures and then show you where the oil is coming from. Hopefully you can make light of what I will be referring to. On the lower unit in the backside where the nut is to remove if needed to change out and up inside is where I think its coming from. Wasn't sure if that nut was loose so I tried to tighten it and slight budge but not enough I don't think to cause a leak. But I also noticed it a bit wet up inside too. See the photo that shows up inside. Also it was green in color so match that to the paper towel I used to clean it up off ground and up inside. Any ideas? Thanks.
