1970 Evinrude 115hp (115083d) correct starter?
ampickles1992
Hey guys,
I've been having starter issues, so decided to pull my starter apart and clean the brushes. In doing so, the brush plate broke, and I'm just looking to replace the entire starter.
I've had a look at some parts online, but the majority of them are stating a 32.3mm gear, but mine is closer to a 40-41mm gear. 10 tooth. The case has two mounting points on one side, then a right angle to the third which is up high.
Can anybody please let me know the correct starter part number for this motor? The numbers on my current starter read MGF 503-1, but from what I came up with this appears to be a starter off a 70hp variant.
Any advice would be awesome! Thanks guys.
ampickles1992
I have the large gear off my existing starter. Is this something that I can just swap the gear from one of the similar starters with the smaller gear? Or will the parts not be compatible?
F_R
I don't know the answer to that question
