Re: 1970 evinrude 85hp, no spark
Voltage on shift wires with the motor off and in neutral/reverse should be about<br />1.2 Volts less than battery voltage as it has to go through a diode to get there.<br />So 10V looks roughly okay, this means you may have a problem in the lower unit<br />but lets get the engine running first.<br /><br />You say you have a new known good amplifier, so we only have a few things<br />left to check.<br /><br />1) Verify points are working correctly. There is a big black wire that goes<br />from the amplifier (via a pull apart disconnect) to underneith the flywheel.<br /><br />With the ignition switch off, disconnect it and connect an ohmmeter between<br />ground and the points wire (Not the amplifier side).<br /><br />Rotate the flywheel slowly and verify that the resistance goes from infinity to<br />zero four times in one rotation. If not, something happened to the points, and<br />you will have to pull the flywheel.<br /><br />2) If the points are okay, test the resistance of the coil. Primary should be less than<br />1.2 ohms, and the secondary should be near, but less than 3000 ohms.<br />Try cranking the motor in the dark, see if you are arcing somewhere around the<br />coil or under the flywheel (where the distributer is located)<br /><br />If you get to this point and still no go, it's time to suspect the new amplifier.<br />Joe Reeves posted a nice way to test this out with a small 12v light bulb in a <br />much earlier post in this forum.<br /><br />Mike
