1970 Evinrude compression test?
smevil
I had a 40 hp 1970 comp. test was 118 and 120 this was done cold?
ADK_Boater
Re: 1970 Evinrude compression test?
What exactly are you asking?
smevil
Curious if these were good numbers, thought they were till I seen an add on C-List calling out 140,s and 135,s.
JB
It would be unusual to be any better, smevil. The important number is the difference being less that 10%. PSI numbers are irrelevant, too many variables and too much obsession about psi.
boobie
And to many variations between compression gauges.
5150abf
They are close and it was cold so they should go to 130 hot, I wouldn't worry, certainly in the ball park.
Good points above, get your own compession gauge and only use it then you will know if there si a change it is the engine and not the gauge and alt of times a good decarb will raise your numbers.
smevil
Thanks guys always helpful. SME
