1970 Evinrude Fastwin Fuel pump
MassBassin
Hello I am losing prime on my gas line while the motor is running and thus the motor will stall. If i prime the ball the motor will recover. The fuel pump is fairly new and appears to be working fine. What should I look for when inspecting the pump to verify this is the problem?Thanks.
jbjennings
Re: 1970 Evinrude Fastwin Fuel pump
Masbassin,
You said it appears to be working fine......How can you tell just by looking?:p
Just messing with you....
You may have an air leak in the hose around the primer bulb, a bad check valve in the primer bulb, or a split or otherwise boogered up pickup tube inside the tank. Most likely, though, your fuel pump isn't working. Take the fuel line that comes from the pump and goes to the carb off of either the carb or the pump, and pull the motor through a few times and see if the pump is pulsing fuel out the hose/nipple.
If it's pulsing fuel out then it's working, if not, either the pump is not getting fuel to it due to the aforementioned possibilities or the pump is bad.
Good luck,
JBJ
F_R
Borrow and try another (known-to-be-good) tank and hose to eliminate that possibility.
MassBassin
hahaha.. You knew what I meant lol. Thanks for the advice i will try both options. Thanks
