alumi numb
Thread starter- Joined
- Nov 12, 2008
- 299
just joined and first post.
i picked this thing up with the intent of scrapping the hull and keeping the trailer.
then noticed the hull was in great shape with no dents at all.
so at this point all wood has been replaced including the cabin wall.
for the cabin wall used 3/4" oak ply coated with minwax helmsman spar urethane.
floor and seats are exterior grade fully sealed using white enamel.
the original wood was not coated at all and lasted at least to this point so i think i'm ok.
the transom is not rotted at all and the lower unit seems fine.
did replace the front motor mount wood.
will replace the impeller as will pull the lower and replace bellows grease and check bearings..
now to the piont.
the engine is stuck as it had set for about 15 years.
i see no evidence of a cracked block, oil looks great as it had no water in it when i drained.
actually the engine looks very nice exterior wise and is complete.
have not taken the engine apart yet so have no true idea what i'm dealing with.
i did pull the valve cover and all looks fine there.
pulled one rocker off and could see no wear to it so i'm taking that as a good sign.
question now is, i see on ebay one can get a rebuild kit pistons and all for about $275.
can the engine be rebuilt in place without having to pull the block?
this looks like it would be the easy way out i'm hoping.
on the other hand.
if all looks good inside was wondering this.
could i just drop the rod caps remove the ridge and pull the piston/rod thru the top.
hone the cyl's and replace rings if tolerances are in then plastigage the old rod bearings.
if they are in then put things back together.
also gen maint like hoses and belts.
are there any hidden things to look for?
were would i look for cracks, the most common places?
if boring should be required can i use 140 pistons or just get the required over size?
i'm trying to make this as easy on myself as can logically be so any help will be met with a thanks and gratitude.
thank you.
now to the piont.
on the other hand.
thank you.
