MegalopsAtlanticus
Thread starter- Joined
- May 15, 2017
- 11
Hi Guys. I finally took the initiative to order a new starter pinion for the pull starter on my 1970 Johnson 6hp. For the last several months since the original pinion split (I run the motor three days a week) I have simply lifted the cowling off the motor and engaged the little black pinion against the flywheel by hand. Then pulled.
Well, I finally found a supplier for a new cowling seal (in England, of all places) so now the cowling fits nice and snugly and I really can't be lifting it on and off every time I start the motor anymore.
The problem I am having is that I don't know how to keep the spindle from unwinding wildly once I drive out the roll pin holding the pinion to the spindle.
Has anyone ever done this job before?
Any ideas on how to keep tension applied while removing the old pinion and sliding a new one one, then re-driving the roll pin? I hope this question makes sense. It appears the internet has no information on how this job is performed. Merely a poorly titled You Tube showing the finished result ( https://www.youtube.com/watch?v=-XDUgaYUyWk ). Thanks in advance if anyone's done this process before and wants to share how!
