1970 Merc 100hp Help....Whats this?
fm elliott
I came into this family heirloom reciently. When I took the top off, there is a right angle port (about 1/4 to3/8") with no hose attached. What's this? I can't find any unattached hoses anywhere, and the manuel doesn't show it. Any help will greatly be appreciated.
(FYI: Good Job Mr. Moderator....corosion on the solenoid wire caused the problem)
JB
Re: 1970 Merc 100hp Help....Whats this?
There is some corrosion in your starter circuit. Take the battery cables off and carefully clean the terminals.
Let us know what you find. :)
fm elliott
Thanks, I'm working on that now. any thoughts on the open water port?
emckelvy
Probably a fitting to connect a water pressure gage. Cap it off or get yourself a gage and hook it up. A good way to monitor your cooling system, BTW.
HTH.......ed
fm elliott
Good idea. I''l check with my brother to see if he had a guage hooked up on his old boat last year. (my concern is: if it's supposed to take water to another area of the motor, and if not connected, will run hot).
Thanks FM
