Would appreciate help from someone with more outboard experience! I have reviewed past messages of people who have had similar trouble, but I need a little more specific help since I am "mechanically challenged". I dropped the lower unit in my 1970 merc. 650 because I had no reverse only a grinding. I found damage on the cam in the top of the shift shaft. I replaced cam and returned lower unit into place. Now I only have forward and no neutral or reverse. I assume from the other posts I found, that I did not return the shift shaft and/or the cam to the proper position. What is the best way to put it back correctly, or is something else wrong. I do not know the position of the shift/throttle at the time of removal of the lower unit. thanks
