smevil
Thread starter- Joined
- Apr 5, 2011
- 123
Ok here it goes, 1970 Evinrude carb fresh rebuild, new float, needle seat all new gaskets, etc. this problem has been on going for months, after you put the carb back together and prime the fuel bowl you hear the fuel fill the bowl, then primer bulb gets tight, as normal. Then turn key engine runs perfect. Second and third day go to prime the bulb you get 1/4 sqeeze on gets tight engine still runs perfect. Here is the problem day three maybe four you go out prime the fuel bulb and it will take 5-7 squeezes after that the fuel will start flowing out the top atmosheric hole on top fwd of the carb.
This has done this time and time again same senario, been in this thing 20 plus times, the one thing that is curious to me is after the 3 day window you go to prime the bulb you have to fill the carb bowl of fuel (you can hear it going in) again the first couple days all is fine, then its like the fuel disapperes out of the bowl you fill it back with the bulb then out the top it comes. I already know it coming out the top when it takes several squeezes of the bulb. Have bench tested the carb every way imaginable the needle and seat shuts air off when blowing perfect. One other thing I can't get my head around is where does the fuel go first couple days the bowl remains full but after that it disappears, should it not stay in the for days if not weeks? SME
