1970 Stamas clearwater 24' rebuild
Crawson89
Hey! First post here, been reading for years!
After completing a refit and refinish of my 1969 viking 22 sailboat, bulkhead replacement, sole replacement, re-coring and spraying fresh gelcoat across the entire topside, I have acquired a 1970 Stamas Clearwater 24' project. I had planned to flip for the value of the trailer, but her lines grew on me, and I've committed.
I am an experienced glass/gelcoat tech and apprentice marine mechanic. I'm comfortable with a project of this size, with dealership access to parts. Have a gm 305 5.0L v8 and alpha 1 gen 1 in good working order to drop into the boat. Originally came with a mercruiser "160" which I cannot find much info on but believe it would've been a ford inline 4 and pre alpha drive. All electrical is already designed and mostly purchased.
I'm currently in the demo process and have removed rotten cockpit sole and am deciding how to proceed with these stringers.. after speaking with Stamas i was expecting solid Doug fir stringers, but came up with foam filled glass stringer/bulkhead skeleton. It appears to have been laid up in a mold upside down, and filled with foam. Then flipped over and glued into the hull. The foam core does not extend all the way down to the hull. The foam coring has de-bonded from inside of stringers, how structural do we think the foam is? I was planning to tab the stringers down, as I'm not happy with original bonding putty holding it all to the hull, but wondering if i should be grinding out all the foam from 6" access holes, refilling with expanding foam and capping with glass before the new floor goes on...
Also, toying with idea of using 1/2" nidacore to replace old 3/4 ply waterlogged floor? Thoughts?
Open to all constructive guidance, opinions, thoughts etc!
Thanks!
mickyryan
go to back of boat by where stringers attach to the transom and drill a couple holes to see if holding water lots of time foamk will dry out if there is holes to let water escape
Mercruiser 160 was a 250 cubic inch GM inline 6. The drive was an MC1.
There is no "pre alpha" drive. However there are 17 various drive models that were used before the Alpha drive
The keyhole cutouts are similar
Agree with micky on the test drills
tpenfield
Following . . .
The foam within the stringer grid is probably not all that structural IF (if) the stringer grid is in good shape otherwise. Do suck the water out with some drill holes (as mentioned) and maybe even tilt the boat to the holes and apply suction from a wet vac.
As far as the nidacore for flooring . . . probably the better bet vs. high density foam. You certainly will want to adhere the flooring to the stringer grid and glass it to the sides of the hull at the chines.
You may want to fill the chambers of the hull (that the floor and stringer grid create) with foam, much like the traditional wood/glass construction. It will give the boat a more solid feel and perhaps give you enough flotation.
kcassells
Nice boat!
The foam in the stringers is basically not for strength. When done there are like 6 layers of glass over the foam for strength. You could easy scalp the tops off to remove foam and then pour new foam back in. After you cut the excess foam to height then roll or brush resin over the open cells so they become closed cells.
Also agree to fill foam in the other cavities or make storage. I've never used nida core. It is definitely more expensive and labor intensive. Here is a thread on guys who used it.
Also here is a read on the various types of 2 part marine foam.
Crawson89
Thanks for all replies and suggestions! Spring yard cleanup has halted progress for a week, but will start drilling access holes and exploring further! Will post progress soon!
kcassells
Yup same here. Cleaning up the yard.
Crawson89
Hey Scott, any idea what the original mounting pattern looked like in the mercruiser 160 vs a 305 v8? My plan is to drop the motor in and align it with the alpha transom assembly while hanging, then measure positions for front motor mounts, motor back out and build the new engine stringers then motor back in.. Any simpler way you can think of to get front motor mount positions for new engine stringers?
Crawson89
Crawson89
Back again with more questions/looking for suggestions!
I have 100% of the old floor removed, scrubbing out all the old scum before grinding all the gelcoat off the entire stringer grid. I have found that the stringer grid is foam filled throughout, with 3/4 ply on the fore and after sides of each bulkhead. The ply is wet, but not rotten... but the foam has debonded everywhere, allowing the vertical glass sides to flex quite a bit.
My plan is to tab the stringer grid down to the hull better than it is currently, then scalp the tops off and dig out all the old de'bonded foam, pour new expanding foam and glass the tops back on.
Any idea if 2lb floatation foam will do the trick? Or should I look into a 4 or 8lb structural foam?
Goal is to stop the sides of the stringers from flexing when I press a finger into them.
Crawson89
Build a cradle to support the hull. Cut out all the rotten stuff and start over with everything
There's nothing inside the longitudinal stringers to rot. They are foam filled.. rebuilding this grid with wood and glassing over will double the weight of the boat.. the flex is caused by the foam having de-bonded on the inside allowing the 3/16" thick glass vertical sides to flex..
Just curious whether floatation foam or a heaver 4# foam would be recommended..
