1970 Stamas shifting (Mercruiser)
Charkate
I put new shift cable on did all the adjustment like the manual but it shifted into reverse but not forward. I started moving the cable up the slot got to the point where it barely got into reverse but still doesn't go into forward.
Bt Doctur
Not knowing how you installed the new cable but if you used the new type you cant have more than 2 threads exposed when installing the cable into the gimbal.
fwd is adjusted first, then reverse with the slotted stud./
